BEASTGRIP X SanDisk
Combine content capture and SSD storage on the iPhone 15 Pro series with accessories for creators from our collaboration with BEASTGRIP®.
Build Your Ultimate Content Capture
iPhone 15 Pro Series Rig
Add your
Beastcage™ is built for your iPhone. Just slide in your iPhone 15 Pro or Pro Max1, use the quick-lock cover to easily attach your phone in seconds, and start filming.
Mount your SanDisk Extreme Portable SSD1
SanDisk partnered with BEASTGRIP® to combine content capture and storage. Help secure your drive with the SSD clamp mount, connect it to your iPhone, and save footage right where you shoot it.
*BEASTGRIP X SanDisk BeastCage + Storage
Bundle shown above.1
Master your rig with
durable gear
Engineered from anodized metal, Beastcage can support the tools you need to transform your rig — like the purpose-built handle for a solid grip on your iPhone videography.
Keep adding phone camera accessories
Check back in with SanDisk and BEASTGRIP for more Beastcage-compatible products so you can keep building your dream iPhone 15 Pro series rig.
Save When You Bundle
Portable SSD
Storage with Your Creator Kit
- Compatible with BEASTGRIP X SanDisk SSD Clamp Mount.
- Supports direct HD recording in ProRes HD on iPhone 15 Pro and Pro Max.
- Solid state NVMe™ performance with read speeds up to 1050MB/s2.
BEASTGRIP x SanDisk Beastcage Creator Kit
- Elevate content capture on your iPhone 15 Pro Max.
- Attach your favorite SanDisk Extreme Portable SSD1 with the SSD clamp mount.
- House your phone in a heavy-duty, secure anodized metal cage.
- Confidently control shooting with the purpose-built handle.
What’s in the Bundle
Beastcage for iPhone 15 Pro Max
Handle
Clamp
M37 x 0.75 lens/filter mount
Moment T - bayonet lens mount
M17 x 0.75 lens mount
M17 - M37 adapter ring
Front mount bracket for the cage (pre-installed)
Cold shoe mount
M5 screws
Allen wrench
Pick your Bundle
BEASTGRIP X SanDisk BeastCage Bundle
Beastgrip, SSD Clamp Mount, Cage Handle
Shop the Collaboration
Explore standalone products from the BEASTGRIP X SanDisk collaboration for your
content capture rig.
Beastcage for iPhone 15 Pro Series
Customize your cage, optimize your iPhone.
What you can do
with it:
- Transform your iPhone 15 Pro Max or Pro into a pro-grade content creation powerhouse.
- Use the fast-locking cover to swiftly insert or access your iPhone.
- Add your favorite compatible filmmaking accessories on ¼”-20 threaded mounts, like lenses, lights, mics, and more.
What you get
with it:
Beastcage for iPhone 15 Pro Max or Pro
SSD Clamp Mount
Long shoots, less hassle.
What you can do
with it:
- Effortlessly hold your SanDisk Extreme Portable SSD (sold separately) or other SSDs during long recording sessions.
- Seamlessly add extra storage on your Beastcage rig while keeping your hands free.
What you get
with it:
Clamp
Cold shoe mount
M5 screws
Allen wrench
Handle GH-50
Add even more control to your content capture.
What you can do
with it:
- Upgrade your camera rig to a top-tier content creation essential with this premium device handle. Crafted from machined 6061-T6 aluminum, it exemplifies exceptional quality and durability.
- Its easy-to-hold shape and knurled surface ensure a confident grip, providing peace of mind during shoots. It’s the go-to accessory for social media creators, travelers, vloggers, and journalists on the move.
Discover New Products and Events from SanDisk
1. SanDisk Extreme Portable SSD and iPhone 15 Pro/Pro Max sold separately.
2. Up to 1050MB/s read speed, up to 1000MB/s write speed. Based on internal testing; performance may be lower depending on host device, interface, usage conditions and other factors. 1MB=1,000,000 bytes.
3. 1TB=1,000,000,000,000 bytes. Actual user storage less
