$i18n{business.forBusiness}
More Drives. More Storage. More Possibilities with the iPhone 16 Lineup.
Save more content. Back up larger files. Record content directly to your drive from your iPhone 162. With Sandisk drives and a reimagined SANDISK Memory Zone app3, your iPhone 16 series device is a production studio in your pocket.
	Expanded Storage & Backup Options for iPhone 16 Lineup2
Push your iPhone 16’s capacity further.
Add compatible USB-C external storage so you can do more with higher-res imaging, video recording, and better performance.
Help protect more of your data.
With expanded storage and backup options, compatible Sandisk drives help keep more of your iPhone 16 series content on hand.
Transfer content across USB-C devices easily.
Quickly move content across Apple devices, whether you’re using SANDISK Memory Zone3 or the iOS Files app.
	Direct-to-Drive ProRes Video Recording, up to 4K 60 fps for iPhone 16 Pro/Pro Max
Capture more ProRes 4K 60 fps video with your iPhone 16 Pro/Pro Max2.
Support iPhone 16 Pro/Pro Max’s direct ProRes 4K 60 fps video recording with compatible portable SSDs, so you can shoot even more blockbuster footage right on your rig.
Get high performance and super-fast transfers.
Optimize your direct ProRes 4K 60 fps video recording workflow with compatible portable external storage offering NVMe™ technology for rapid read/write speeds.
Free up your device’s internal storage for more content.
Boost your iPhone 16 Pro/Pro Max’s capacity with compatible portable SSDs up to 8TB4 —that’s more space for footage and more potential for your internal storage.
iPhone 16 Compatibility2
| SANDISK Creator Phone SSD |
| SANDISK Phone Drive with USB-C |
| SANDISK Creator Phone Drive |
| SANDISK Extreme Portable SSD |
| SANDISK iXpand Flash Drive Luxe |
| SANDISK Ultra Dual Drive Luxe Flash Drive |
| SANDISK Ultra Dual Drive USB Type-C |
| SANDISK Ultra Dual Drive Go USB Type-C |
| SANDISK Ultra USB Type-C Flash Drive |
| SANDISK Ultra Luxe USB Type-C Flash Drive |
| SANDISK Ultra Slider USB Type-C Flash Drive |
	BACKUP SOFTWARE
SANDISK Memory Zone
SANDISK Memory Zone is the easiest way to back up data to Sandisk devices and make space for new content.3 Save it on here and share it out there — right out of the box.
Related Content
1. See iPhone 16 Support Page for a full list of compatible Apple devices.
2. iPhone 16 Plus/Pro/Pro Max sold separately.
3. Download and installation required. See https://shop.sandisk.com/topics/accessories/memory-zone-2-0-backup.
4. 1TB = 1,000,000,000,000 bytes. Actual user capacity less.
										 iPhone 16 / 16 Plus
iPhone 16 / 16 Plus iPhone 16 Pro / Pro Max
