ZNS SSDs
Accelerating applications for data at scale
Higher Performance
Up to 4X the workload capability compared to conventional NVM SSDs
Higher QoS
Lower complexity of operations results in up to 65% lower tail latencies, translating into higher quality of service (QoS)
Higher Efficiency
Eliminates device garbage collection to return storage resources to the user
The rate of human- and machine-generated data is outpacing industry bit supply. Data centers need to maximize storage efficiency and utilization to keep up. Zoned storage is the answer.
Zoned storage SSDs allow applications to sequentially write data into distinct zones which can lead to improved data placement and data management. Zoned Namespace (ZNS) NVMe™ 1.0 SSDs eliminate device garbage collection which leads to higher performance and higher QoS.
ZNS SSDs improve overall data center system efficiencies and utilization, enabling multi-tenancy and helping data centers meet the challenges of explosive data growth.
Application Acceleration
If you use RocksDB, we can make it better
ZNS + RocksDB = Maximum Performance
Many of the next-generation “NewSQL” databases leverage the power of RocksDB as their storage engine. Western Digital has created ZenFS, a file system plugin that allows for RocksDB-based applications to directly integrate with ZNS devices. This plugin eliminates background garbage collection on the SSD and file system to leverage the full performance of the underlying flash media.
Use Western Digital’s open-source contributions, with little to no modifications, to supercharge your RocksDB-based workloads on the ZN540.
Feature Download
Explore the possibilities of zoned storage
