How to Manage Your Drives with Sandisk Dashboard
Enhance PC System Efficiency with Pro-Level Drive Monitoring
Managing your drives efficiently is crucial for maintaining system performance and storage health. This guide will walk you through the process of managing your Sandisk storage drives using the Sandisk Dashboard app. Everything from monitoring your drive’s health and updating firmware to customizing LED RGB controls can happen securely right from the app.
Materials Needed
  • Sandisk SSD (check compatibility with system)
Software Needed
Easy
Difficulty
10 Minutes
Time
Step-by-Step Guide to Managing Your Drives Using the Sandisk Dashboard App
Follow along below or
watch the video.
STEP 1
Download and install the Sandisk Dashboard app
  • Power up your computer and make sure your operating system is fully updated.
  • Visit the Sandisk Support website and download the Sandisk Dashboard app.
  • Install the software on your computer.
STEP 2
Connect the new SSD
  • If your drive is external, connect it to your computer using the appropriate cable (e.g., USB).
  • If your drive is internal, ensure it is properly installed inside your computer. Not sure how? Learn how to upgrade your system.
STEP 3
Launch the Sandisk Dashboard app
  • Open the Sandisk Dashboard app on your computer.
  • The app will automatically detect your connected drives.
STEP 4
Update firmware
  • Go to the “Firmware” tab to check for available firmware updates.
  • If an update is available, follow the on-screen instructions to download and install the latest firmware for your drive.
STEP 5
Monitor drive health
  • Navigate to the “Status” tab to view the health and status of your drive.
  • Check parameters such as temperature, available space, and drive health status.
  • Address any warnings or alerts promptly to maintain optimal drive performance.
STEP 6
Perform diagnostics
  • Navigate to the “Tools” tab to access diagnostic tools.
  • Run quick or extended diagnostic tests to identify and troubleshoot any issues with your drive.
STEP 7
Optimize drive performance
  • Scroll down on the “Tools” tab to the “Optimizations” section to customize your drive's performance.
  • Monitor drive performance metrics such as read/write speeds.
STEP 8
Customize settings
  • Go to the “Settings” tab to customize various app and drive settings.
  • Adjust settings such as notifications, power management, and language preferences to suit your needs.
  • If you have a WD_BLACK drive, your drive may come equipped with extras like RGB Lighting Controls and Heatsink monitoring. You’ll have the ability to adjust them here.
By following these steps, you can effectively manage your drives using the Sandisk Dashboard app, helping ensure optimal performance and data protection.
For more helpful tips, visit: Sandisk.com/Support.
Related Content
UPGRADE
How to Install an M.2 NVMe SSD in a PC Laptop
Follow this step-by-step guide to upgrade your laptop to a Sandisk M.2 SSD for more speed and storage.
Read More
UPGRADE
Upgrade Your Desktop PC to an M.2 NVMe SSD
Follow this step-by-step guide to upgrade your desktop to a Sandisk M.2 SSD for high-capacity and high-performance storage.
Read More
UPGRADE
How to Upgrade Your Desktop HDD to a 2.5" SATA SSD
Upgrade your desktop’s 3.5” hard disk boot drive to a Sandisk 2.5” SATA SSD to give your PC a boost in speed and capacity.
Read More
UPGRADE
Upgrade Your PC Laptop Hard Drive to a 2.5” SATA SSD
Upgrade your laptop’s 3.5” hard disk boot drive to a Sandisk 2.5” SATA SSD to give your system a boost in speed and capacity.
Read More
Sandisk and the Sandisk logo are registered trademarks or trademarks of Sandisk Corporation or its affiliates in the US and/or other countries. Western Digital is a registered trademark or trademark of Western Digital Corporation or its affiliates in the U.S. and/or other countries. Acronis and True Image are registered trademarks of Acronis International GmbH in the United States and other countries. The NVMe word mark is a trademark of NVM Express, Inc. All other marks are the property of their respective owners.
