Get More Out of Your Chromebook
With our “Works With Chromebook” certified SanDisk memory cards, you can store more, share more, and do more with your Chromebook.
How It Works
We worked with Google to test and certify select accessories and storage solutions to integrate seamlessly with your Chromebook. The products are certified to work with current and future Chromebook devices.
Easy, Add-On Storage for Your Chromebook
A great fit for students and professionals of all levels, Chromebooks are smart and secure computers that stay on-the-go with you. In today’s content driven world, it’s easy to use up data storage space available on your laptop.
From book reports and presentations to your next viral video, our “Works With Chromebook” certified products make it easy to keep your files in one place. With our SanDisk memory cards, you can choose how to upgrade your Chromebook’s storage.
“Works With Chromebook” Certified Products
Shop SanDisk memory cards in capacities that fit your needs for Chromebook.
SanDisk Ultra microSD Card for Chromebook
Fast memory that’s with you at all times.
Instantly add to your Chromebook’s capacity. The SanDisk Ultra microSD UHS-I memory card gives you up to 256GB1 more capacity for an instant upgrade to your Chromebook. And with transfer speeds of up to 120MB/s2 you’ll be able to move your content fast.
  • Tested and certified to sync with your Chromebook
  • Add more storage so you can save and share more of your files
  • Watch videos with Speed Class 10 for Full HD video playback3
  • Waterproof, temperature proof, X-ray proof, and more4
Additional Resources
Warranty-backed products for reliabilityand peace of mind.
Free Download
Free software downloads to help streamline your productivity.
Full Support
Online and phone support available in most areas.
These footnotes/disclosures are incorrect and need to be reordered based on the sequence they appear in on the page.
1. 1GB=one billion bytes. Actual user storage less.
2. Up to 120MB/s read speed, engineered with proprietary technology to reach speeds beyond UHS-I 104MB/s, requires compatible devices capable of reaching such speed. Write speeds lower. Based on internal testing; performance may be lower depending on host device, interface, usage conditions and other factors. 1MB=one million bytes.
3. Full HD (1920x1080) video support may vary based upon host device, file attributes, and other factors. See: www.sandisk.com/HD.
4. Card only. See www.sandisk.com/proof.
เปรียบเทียบ
